Not your typical th400 speedo question....builders inside
Old Jan 10, 2008 | 07:28 PM
xssive's Avatar
Default Not your typical th400 speedo question....builders inside
I want to go ahead and install a speedo sensor setup on the transmission. My output shaft looks like this one :
It looks like it has a metal speedo drive gear built into it already? instead of the usual plastic gears im used to?
Old Jan 10, 2008 | 09:33 PM
FLT's Avatar
FLT
The metal one on there is just pressed on. You will need a puller to remove it or heat it with a torch and remove it with a hammer and a punch. Then you will be able to install what ever setup you wish. IIRC the one that is on that shaft is a 15T. Vince
Old Jan 10, 2008 | 09:56 PM
xssive's Avatar
Perfect vince! I was hoping you would know how many teeth that was. Ill use it anyways since im goin with an autometer sender
