Blown Tranny???
but on my second to last run i heard a small clunk and a hard shift from 2nd to 3rd but ran fine after so were about to all head home its about 2am and the boosted fox bod wants to try a 50mph roll so we start in 2nd @ 50 i hit it then moved the shifter to D to let the auto shift for me, im about a car ahead but as it hits 3rd i hear the rev limiter! WTF! had some vibration when i let off but i have a polly trans mount, go to get back on it and nothing...no gear whatsoever check im not in neutral
stop under a overpass shut the car off look under with a flashlight no trans fluid no rear end oil pushed it ten feet it rolled fine started it back up and have nothing foreward or reverse in any gear!!! with the engine running i heard a slight random knocking/tapping from the converter area soo. . .who knows wtf happened? it was built almost a year ago with a beast sunshell, billet servo's, alto clutch bands, and a 3000 stall converter (not sure what brand) . . .anyone?? You are obviously making enough power that you need a very well built unit. You need a professional who knows how to get it done right the 1st time without having to send it back in a few times for repairs. You need a Racing Transmission not a "built" transmission.
There really is more to it than just putting in good parts.
Good Luck.
g
all three holes in the flex plate had a crack all the way to the outer ring gear and this colar thing (forgot what he called it) that locks to the converter shaft pretty much exploded into two, thats the part that f***'ed up the pump i told him to hook me up with a tci flexplate but is there an upgrade part for that collar?? or did that just break cuz of the flexplate cracking ? The Best V8 Stories One Small Block at Time
any suggestions?? as a word of advice....my t/a is also my daily driver; if you want it to be a reliable car, dont be ripping on it 24/7. give it a nice run once or twice a week
. But, that's racing. I really cannot say who should accept responsibility. Parts failures cannot be predicted. It is possible that the output shaft was cracked at the time of the build. But it is possible that it was not. My opinion, without seeing it would be that it probably was either cracked or twisted... but that is only an opinion. Take it for what it is worth.
I tell you that because anytime there is a significant failure like you had each and every hard part needs to be very closely inspected. Nothing can be taken for granted in a case like that.
As far as responsibility... it is a judgement call. Do not be abusive with them, that will get you nowhere. Ask them their opinion about why it failed and go from there. I would probably offer you a concession of some sort if it was here at my shop, but I cannot say that deinatively because I do not know all of the circumstances. Most likely though, I would offer to provide the labor and you provide the parts.
If your builder does not have much high Performance experience then they may not know what to look for because they do not see units that have high stress failures each and every day like racing shops do. It's a fact.
Good luck man. I wish you the best.
g
I have seen it , It could just be a weak shaft, It could be the accums are blocked and its was shifting really hard or line presure really high. But the ones I have seen actually happened when a rear end failed . I would definatley inspect that.
Oh no! dont tell me that! Dam I hope not!!...this happened right at the 1-2 shift point close to 6k rpm's and it was not a hard launch I just eased into it... I actually was shooting vid of the guages when it broke. Lol I had just got my shift points changed and was going to compare the new vid with the old one of a 0-130mph run I shot and compare shift points...I should post that vid also Its kinda funny!
