TC lockup question
Old Mar 1, 2008 | 02:00 PM
DRIVER456's Avatar
I put the new TCC solenoid in and with the car on jack stands I put it in 3rd gear and about 35mph I toggled the TCC solenoid on and off and its working!!,I can see the rpm's change & feel the TC lock & unlock.I looked at the old solenoid closer and it was broke,It got caught on the end of the work bench when I lifted the tranny up onto the work bench,But I didn't notice any damage till I look at it closer.Once the roads clear up I'll take for a ride and see what happens.Thanks for all the help.................Paul
Old Mar 1, 2008 | 03:05 PM
joecar's Avatar
Originally Posted by DRIVER456
I probed the wires on that solenoid and toggled it on & off.ON it was at 10.73 volts & OFF was 0.00 volts.I put the volt meter on the battery and it was 11.23 volts,So I take it the solenoid is bad?.................Paul
That indicates:
- failed/damaged solenoid (no click),
- the circuit is functioning correctly;
Good work, good use of diagnostic tools (using bidi controls and probing circuit with voltmeter).
Old Mar 9, 2008 | 03:51 PM
DRIVER456's Avatar
Ok I put the new solenoid in,I'm logging the trans parameters its saying in the log that the TC is locked but it does not lockup.I used the Bi directional controls and commanded lock up and it locked up! I upped the TCC pressure but still nothing,It felt like its shuttering alittle when it says its locked,But with the BiDi controls no shutter or slip,It was fine.Could it be the PCM since I changed from a 97 pcm to a 99-02 pcm? I read some where you can hook a switch for it to lock up,Anybody know where that is?..................Paul
Old Mar 9, 2008 | 04:32 PM
performabuilt's Avatar
LS1Tech Sponsor
When you did your trans build did you disable PWM mechanically ?
If so you would only need to ground the tan wire with a black stripe to cause full lockup , This will set a code for TCC solenoid electrical but you can disable that code reporting if it does and continue your test. Now if you havent disabled PWM then that could be your issue also only allowing partial lockup. Or a restricted PWM solenoid screen, Ussually that will set code P1870 though Unless reporting for that code has been turned off also
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 9, 2008 | 04:58 PM
DRIVER456's Avatar
In the trans DTC Fault Processing Enablers,Its either YES or NO I have YES.In Trans Failsafe Enablers I had YES so I put it to NO,Could that have been the problem? MAX Pressure Enablers I have NO.I don't remember what I did in the valvebody.Like I said it worked fine before I changed the PCM and worked on the 3-4 clutches I'll try it again during the week and see if putting the TRANS FAILSAFE ENABLERS to NO and see if it works.And there are no codes.Thanks Frank.............Paul
Old Mar 9, 2008 | 05:14 PM
LS1Tech Sponsor
Your allways welcome.
__________________
Call 888-744-6542
Old Mar 21, 2008 | 03:58 PM
DRIVER456's Avatar
OK I got the TC to lockup on its own but I have to stab the throttle for it to lockup.Any idea's why?................Paul
Old Mar 21, 2008 | 10:29 PM
joecar's Avatar
Paul,
Check that these are working right:
- TPS sensor,
- VSS sensor,
- TCC brake switch.
and that you're not getting any misfires.
Old Nov 3, 2008 | 03:55 PM
allbaugh_04's Avatar
Did you ever figure out the problem Paul?
Old Nov 3, 2008 | 05:57 PM
DRIVER456's Avatar
Nope.Ever since I changed the PCM from a 97 to a 02 PCM It does not lock up on its own.I made a lockup switch,But that's getting to be a pain ,And some times if I stab the gas peddle it will lockup.This winter I will check things out and get back to this thread.................Paul
Old Nov 4, 2008 | 03:21 PM
how long have you had the problem and dealt with it this way?
i actually wouldn't mind commanding lock up
Old Nov 4, 2008 | 05:52 PM
  #32
DRIVER456's Avatar
Almost a year now.You'll get tired of that switch.I only need lockup in 4th on the highway anyway.But sometimes when coming to a toll or a stop I forget to turn the switch off and the car starts chugging along and I scramble for the switch.I'll fix it this winter......I hope.......Paul
Old Nov 5, 2008 | 10:42 PM
  #33
how exactly do you wire this up...is there a write up somewhere?
Old Mar 26, 2009 | 08:29 PM
  #34
Did you ever fix it?
