turbo 350 install cost?
Old Feb 6, 2003 | 07:47 AM
FASSTLT1's Avatar
Default turbo 350 install cost?
I have a lt1 and was looking into a turbo 350 tranny install. I called Century automotive in rosenburg. They quoted me 995 for the tranny and 700 for labor! Is that a little high or am I just cheap? I need your advice before I get high-grossed. thanks
Old Feb 12, 2003 | 11:50 PM
CharleSS's Avatar
Default Re: turbo 350 install cost?
Talk to Madman. He is WAY cheaper than that!
(If you can do the work yourself, see Ross House.)
CharleSS
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
<small>[ February 13, 2003, 12:16 AM: Message edited by: CharleSS ]</small>
Old Feb 14, 2003 | 10:41 PM
CRZY747's Avatar
HMMM high grossed hu, I bet your a rice salesman, or do u just give them away.
Well anyways the th350 is not the only thing you need a shifter, the tranny and a stall. Is the price you quote with all these things I bet not, you will end up paying close to $1200 to get it, how soon till you have the car back, I just might know someone that will do it cheaper and get a better trans From TRANSKING IN GALVESTON
See ya
<img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Old Feb 15, 2003 | 10:41 PM
MachoTA's Avatar
How complicated is the switch. And also what to the parts cost minus tranny and converter
Old Feb 15, 2003 | 11:28 PM
CRZY747's Avatar
Hmm not that complicated you might need a new flywheel if you are going from a 6 speed to the Th350, you will have to measure out a new drive shaft, possible things that you might need, shifter, tans break button converter, tranny fluid , mounts for it , trans sending unit if you want to be able to see how fast you are going , the tranny of course and someone that knows how to put it in
very simple
JET
Old Feb 16, 2003 | 04:33 PM
MachoTA's Avatar
I have a th350 with a 4000 stall out of my old car lsitting around. Installing it is no problum I was just currious on whats involved. I was also told the driveshaft will fit with a 6 inch tail shaft?
