put trans back in now gas guage and tcs not working???
Old Feb 5, 2008 | 11:44 PM
01ws666's Avatar
Default put trans back in now gas guage and tcs not working???
So I just got my car back from the trans shop today after two weeks and now my gas guage is pinned on E.... Filled it up and nothing... check guages light is NOT on like it normally would be if I was low on fuel... Also my TCS does not work now, when I first turn the car on it will turn on and off like normal then as soon as the car moves my TCS off light comes on I looked under the car around the trans. and didnt see any unplugged connections and also checked above the rear axle at the block of connectors there and everything seems to be where its supposed to be...checked the TCS fuse and the guage fuse both are good... I'd rather just fix the prob myself if its something simple, did searches for gas guage not working and TCS not working and didnt find any other helpfull advice, any other suggestions as to where to look would be much appreciated! Thank you!
Old Feb 5, 2008 | 11:57 PM
getusumws6's Avatar
tcs could turn off if you drive it a few min. as far as the gas sounds like something is unhooked or not grounded properly. maybe codes?
Old Feb 6, 2008 | 12:35 PM
Gilbert@Ace Racing's Avatar
Check each and every fuse on the car.
g
Old Feb 6, 2008 | 03:58 PM
01Z0H6's Avatar
Man, that sucks... Take the car for a tranny... ends up with other problems..
How's the tranny?
Old Feb 6, 2008 | 04:39 PM
FLT's Avatar
FLT
g
Gilbert is dead on here. Many times a fuse gets zapped mysteriously during the swap. I would highly recommend doing as Gilbert has stated first. Vince
