Th400 problems
Old Feb 12, 2008 | 11:28 AM
RICE ETR's Avatar
Turbo Addict
Default Th400 problems
I just swapped another stall in and after a few hard runs my tranny is spewing fluid out the front seal....guess I damaged it when I put the stall in. Question is if I am somewhat mechanically capable, could I just replace the seal myself or should I have my builder check the entire tranny out for other issues?
What are the chances that it is even the seal or did I mess something else up?
I caught it before the fluid level got low fwiw
Thanks,
-Jarrod
Old Feb 12, 2008 | 01:13 PM
FLT's Avatar
FLT
I would at least have the pump bushing inspected and in most cases replaced. It would probably be best to take it to a builder to have this done. IMO Vince
Old Feb 12, 2008 | 05:58 PM
jxaxsxoxn's Avatar
Had that happen before, the bushing walked forward and opened up the seal, fluid hit the header and caught fire. I was in the middle of nowhere, kept driving and it eventually stopped leaking-bushing moved back.
$15 later, new bushing and seal, never leaked again, that time I staked the bushing in place.
Old Feb 12, 2008 | 07:24 PM
RICE ETR's Avatar
Turbo Addict
hmmm...ok well I should be pulling it out tomorrow so I will check the bushing out...do I need anything special to press it in?
Thanks guys
Old Feb 12, 2008 | 07:42 PM
8a8mfh's Avatar
A bushing driver. Or two thick washers and a bolt I guess might work.
You need to stake it in place, and I'd also put red loctite around it after cleaning the bushing and pump.
Then put the pump on a converter to see if it spins free, if not the bushing was driven in crooked. Put the seal in last, after testing this.
Old Feb 13, 2008 | 07:17 AM
RICE ETR's Avatar
Turbo Addict
I think I can handle that. I was looking through some rebuild how-to's and keep seeing people stressign to use the teflon O-rings....are these on the pump somewhere?
Old Feb 13, 2008 | 07:45 AM
FLT's Avatar
FLT
Teflon sealing rings. This has nothing to do with the leak but I do use them on my builds. Vince
