LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Can you calculate converter slippage from dyno?? (https://ls1tech.com/forums/automatic-transmission/86319-can-you-calculate-converter-slippage-dyno.html)
C4VetteLS1 07-13-2003 05:24 PM
If i take the MPH and RPM readings from a dyno pull
I should be able to calculate the percent slip from this correct
How do i calculate it correctly? say i should be at 140 mph @ 6000 rpm...and it shows im doing 130 mph @ 6000, would that slippage be 140/130 or 130 divided by 140??
Jammer 07-13-2003 11:51 PM
Re: Can you calculate converter slippage from dyno??
hmmm, your onto something...me go play with calculator
Ragtop 99 07-14-2003 07:59 AM
The rpm readings on a dyno jet are skewed by a high stall converter. For a stock converter the answer will be pretty close; for a 4000 stall with long shift extension, there will be a lot of error.
Use ATAP and log the input and output shaft speed and you'll have your answer.
© 2024 MH Sub I, LLC dba Internet Brands
