HELP!!!!! older 4l60 in to a ls1 car
Old Feb 14, 2008 | 08:45 AM
OUTLAWZ RACING's Avatar
Default HELP!!!!! older 4l60 in to a ls1 car
Im putting in a older 4l60 out of a lt1 car into a ls1 car (dont ask me why money was the issue) But the wire for the speedo of the car harness dosent match the plug on the tranny. Its a two prong plug is there an adapter or can i splice them into the lt1 plug to make it work.!!!
Old Feb 14, 2008 | 10:00 AM
performabuilt's Avatar
LS1Tech Sponsor
I have not personally done it however I have heard several people say they have spliced it in with no issue. I know the reluctors are the same so I would think it would work just fine.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 14, 2008 | 10:13 AM
383lt1impala's Avatar
what do u mean spliced i have the level 2 in my impala but i want to put it in my ls1 camaro.
Old Feb 14, 2008 | 10:40 AM
LS1Tech Sponsor
Well some people splice the two wires to the right plug, But also note that then converter will require and adapter to work.
__________________
Call 888-744-6542
Old Feb 14, 2008 | 11:29 AM
but will the bell housing bolt up? and where can i get the adapter?
Old Feb 14, 2008 | 11:36 AM
Ok cool i thought so just wasnt sure
Old Feb 14, 2008 | 11:39 AM
The bell will bolt up but you will need a spacer I think huges sales on at summit.
the build is in this order
lt1 4l60 ls1 flex plate and lt1 conveter. But the crossmember gave me hell you will need a lt1 cross member and you will have to do some fab work. the bolt holes onthe driver side wont line up.
Old Jun 27, 2008 | 08:07 PM
TURBHOE's Avatar
12 Second Truck Club
what if you want to do the exact oposite? ls1 4l60e onto a 97 4.3l sierra? ls1 is going in but not right now
Old Jun 27, 2008 | 10:38 PM
wbwhiteboy's Avatar
i bolted up a lt1 4l60e tranny up to a LS1( 5.3l) and it worked fine for the first few times i took it out, but thats cause the bellhousing was cracked so it just broke off from the torque!!
