Guys running a 4L80E, come inside.
Old Feb 21, 2008 | 04:16 PM
1hotls1's Avatar
Default Guys running a 4L80E, come inside.
I recently finished my conversion and I love it. The one strange issue I'm having is that the torque converter will unlock any time you let off the gas, but as soon as I step back into it the rpms climb for a second and then it locks up again. Its not a big deal, but when the cruise is set it can get a little annoying. Is this part of the truck tune that was inserted to control the 80 because I know my lockup point is set properly, but it just continues to do this? Thanks for any help on this.
Old Feb 21, 2008 | 04:25 PM
RamAir02TA77's Avatar
Yea I have the same problem im pretty sure its something to do with the truck tune I just set mine to lockup at 65mph for now until maybe someone can figure something out. Im also not sure if my lockup is completly right sometimes it feels like it slips other times it feels like it fully locks. The converter was purchased brand new and only has like 250 miles on it and its been doing this since installed.
Old Feb 21, 2008 | 10:34 PM
Tiger2o69's Avatar
I am also having this problem. I havent had time to look at the tune much though.. Maybe someone has figured it out..
Old Feb 21, 2008 | 11:24 PM
Websy21's Avatar
Hmmmm MightyMouse would be the man, he street drives his all the time and has run his for quite sometime now.
Old Feb 21, 2008 | 11:28 PM
DeltaT's Avatar
That's a factory mileage trick, to unlock on deccel IIRC. Less drag that way than locked directly to the tranny when you aren't on the gas and producing power. You might have an option to change it depending on your tuner SW.
I know my 80E controller acts this way from the factory too, though it's a TCI..
Jim
My site: http://home.mindspring.com/~jim_fisk/id1.html
Old Feb 22, 2008 | 08:18 AM
Yea im pretty sure hp tuners doesnt have this capability in it yet. Maybe support or something over there could add it? Does anyone elses lockup seem to not lock then fully lock?
Old Feb 22, 2008 | 08:29 AM
1hotls1's Avatar
Mine seems to lock up fine, but the constant unlocking on deceleration is bugging me. Thanks for all the info guys. I guess one of the tuning gurus will figure this one out when they make the swap. Keep me posted if any of you figure this out.
Old Feb 22, 2008 | 11:47 AM
Z'mnypit's Avatar
Weird, mine isnt doing this. Once it locks its will stay locked. Ill look in my tune and see if I can find anything that would cause this.
Old Feb 22, 2008 | 02:23 PM
Yea I heard maybe a certain truck program wont do this like a certain year or something or so I have heard. That info could be false for all I know.
Old Feb 22, 2008 | 04:44 PM
Tiger2o69's Avatar
the only time that it really bothers me is if im going down a curvy road about 45-55mph it keeps going back and forth and drives me crazy. Im sure its not good on the gas either.
Old Feb 22, 2008 | 05:10 PM
Yea I just set mine for highway 4 now it seems alot better. It has to be better for the lockup clutch as well sure a stock truck lockup clutch is probably able to handle all them unlock lockup but a little 10'' clutch couldnt be as good.
Old Feb 22, 2008 | 06:16 PM
Gilbert@Ace Racing's Avatar
If any of you guys can send me a .bin file from EFI Live software I can take a look at the Lock Up strategies to see where an adjustment can be made.
Some guys have sent me a "screen shot" of their files in the past using Hp Tuners and that has been useful as well.
g
Old Feb 22, 2008 | 11:17 PM
DeltaT's Avatar
Does tapping the brakes unlock it immediately?
Jim
Old Feb 22, 2008 | 11:39 PM
Tiger2o69's Avatar
hmm maybe we need to make a post in the tuning section.
Old Feb 23, 2008 | 12:40 AM
performabuilt's Avatar
LS1Tech Sponsor
Good idea and yes tapping brakes will unlock it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 23, 2008 | 08:42 AM
cablebandit's Avatar
hptuners uses a 00 80e segment when they do the swap for you...it will stay locked on decel. Efilive uses a 02 segment for the swap and it unlocks on decel. It is a fuel mileage strategy that we are not able to access directly.
Old Feb 23, 2008 | 09:05 AM
Thanks for the clarification. It is useful info for certain. I was not aware of these strategies.
g
Old Feb 24, 2008 | 12:32 AM
DeltaT's Avatar
That question was for the OP to try and figure out his problem I know how it's supposed to work...
Jim
Old Feb 25, 2008 | 08:16 AM
1hotls1's Avatar
Are you saying that the only way to stop this is to use the 00 80e tune? I was hoping there would be some way to adjust this in the tune.
Old Feb 25, 2008 | 09:06 PM
1hotls1's Avatar
Are any of you running the yank crossmember and does it cause your torque arm to rub the driver's side of the tunnel?
