4L60E to TH350/TH400?
What's all needed to make the swap? I know you need a new driveshaft, cross member, and converter. I know you can also use the stock shifter...is the anything else needed? does the PCM need to be reflashed? It'd be nice to see everything listed out
thanks
thanks
