Huge Vibration Issue
Old Mar 10, 2008 | 03:28 PM
XxWs6MaNxX's Avatar
Changed my tranny mount from the energy suspension garbage one, back to a oem mount, and it is as smooth as a baby's ***........
Old Mar 10, 2008 | 09:49 PM
SuperSport01LS6's Avatar
Just the mount made that big of a difference huh? Well Im just waiting for the flexplate to come in. After i install im hoping i should be in the clear. Just wondering but you wouldnt happen to have looked at your flexplate while your engine was running by any chance? does it spin perfectly flush and true?
Old Mar 11, 2008 | 01:55 AM
XxWs6MaNxX's Avatar
no i didnt go into it that far.............just figured that the tranny mount was the cause of the problem i only changed the verter and the mount so i decided to investigate one or the other, and repaced it........man and when i say i had a huge vibration it was horrible, shook the steering wheel, center console to peices from any rpm. Even in park, and the whole car felt like it was gunna fall apart! Concider looking into a 20 dollar tranny mount from napa, or part number A2817 from autozone (or the oem from chevrolet dealershit which will cost u 91 dollars) before u go any farther. I was under the impression that my verter was unbalanced, or i had bent the flex plate. just a thought.......but your case may be different! Put your stock cross member back on with the stock mount and see if it helps?
Old Mar 11, 2008 | 09:25 AM
Sounds Good, im determined to get this thing running smooth by this weekend thanks for the help to everyone
Old Mar 11, 2008 | 06:27 PM
hotrod44_4u's Avatar
does anybody know where i can buy a 6.0L short block stroker with the best forged parts for the cheapest? forged crank, rods, pistons, rings,bearings, bolts thanks for any help
Old Mar 12, 2008 | 01:09 AM
New Verdict.. Well YANK was 100% correct as far as the vibration issue. For some dumb reason GM put two little ears that hang down on the stock trans mount. With the new YANK cross member those ears hit the brace and caused a crazy rumble affect in the car. I should have paid more attention. Just didn't crossed my mind. Thanks YANK for the tip! No more Vibrations and I'm loving the SS4000. Perfect Verter
Old Mar 12, 2008 | 04:34 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
PHP Code:
I ordered A hawks racing SFI approved plate today
Which flexplate did you order from them - as I don't see one that is listed for our application?
Was it a quality part? I was going to buy a Meziere flexplate but price is ginormous The Hawks are really cheap price - just wondering if old addage applies - 'you get what you pay for'
-Jay-
Old Mar 12, 2008 | 09:12 AM
Actually i got it off ebay from raceparts store. I typed in ls1 flexplate and it came up with a hawks racing one. Its SFI approved double welded and zero balanced. plus thicker with .125 thickness instead of stock .075. Honostly i think its the same company that makes B&M flexplates it looks identical. got it for 76 shipped! I have ordered other ls1 related items from this supplier off ebay they havnt let me down yet
Old Mar 12, 2008 | 09:41 AM
1QUIKWS6's Avatar
Thanx for the info - I'll check them out
Old Mar 12, 2008 | 08:45 PM
XxWs6MaNxX's Avatar
glad to see you figured it out brotha! I couldnt believe it either that a tranny mount in a bind would cause that much vibration!
Old Mar 12, 2008 | 09:12 PM
Yea I know it literally felt as if the car was falling apart. Its amazing what little key components could do for a car and its ride quality!
