A4 to M6 swap info...
Old Feb 26, 2003 | 11:58 AM
supersp0rt's Avatar
Default A4 to M6 swap info...
i know this has been discussed 386783096 times, but the search function didnt turn up too much. i guess i want to know what needs to be changed; so far i know tranny itself, clutch and pcm...what about torque arm and driveshaft? anything else im missing? i MAY attempt to do this and if i can pretty much evenly exchange everything. i figure instead of saving the money for a built auto and still leaving the rear in question, i can trade my auto for a 6-speed and then use the money that i would have used on the built auto for a 12-bolt and, hopefully, come out on top. any and all help and insight is appreciated.
Old Feb 26, 2003 | 08:20 PM
G5TA's Avatar
Default Re: A4 to M6 swap info...
I'm in the process of it right now. You will need the pedals and the tranny its self.Also you wont need to trade the Pcm if the other person dont need it.Im just getting LS1edit to program out the tranny.The hard part i have run into cutting the hole for the master cyl.Im a big guy(6'4 300) and its hard for me to get in there but its not that bad.The pedals comes out all at once.
