whats the normal trans. temp?
Old Mar 12, 2008 | 08:46 PM
TXjeepTJ's Avatar
Default whats the normal trans. temp?
i searched and searched and read sticky after sticky, cant find the answer. what is the normal operating temp. of the 4L60e?
Old Mar 12, 2008 | 09:02 PM
performabuilt's Avatar
LS1Tech Sponsor
That varies alot suffice it to say that as long as your not going over 220 you should be fine cooler is better. But now with a high stall or of you have the sender in the presure port you may see intermitant in the 230- 240 range when running hard. Personally I like them as cool as possible.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 14, 2008 | 10:25 PM
TXjeepTJ's Avatar
haha soo i guess 145 degrees is ExTREMELY good
