Installing new slave in my '98 formula
Old Feb 27, 2003 | 09:30 PM
cy's Avatar
cy
Default Installing new slave in my '98 formula
I need some instructions on this. I have a Chilton's manual for a manual for up to '97s, will this work for my '98? Are the T-56's the same between the years?
Are there any good places to look for information on how to do this?
Old Feb 28, 2003 | 01:42 AM
cy's Avatar
cy
Default Re: Installing new slave in my '98 formula
Anyone, help?
Old Mar 1, 2003 | 12:03 AM
cy's Avatar
cy
TTT
Old Mar 1, 2003 | 12:34 AM
Jason99T/A's Avatar
I can shift faster than you.
The '97 manual will not work for this. The LT1s had an external slave, while the the LS1s have an internal slave. To change it, you will need to pull the transmission. Once the tranny is out, it is only 2 10mm bolts that holds the slave cylinder to the tranny.
If you need some info on how to pull the tranny out, let me know.
Jason
Old Mar 1, 2003 | 04:21 PM
cy's Avatar
cy
Ahh, thought so. Ya, i need some instructions on how to pull the tranny.
Instructions and any special things i should know/do would be a great help.
Thanks.
Old Mar 2, 2003 | 08:02 AM
TrackBurger's Avatar
Heres one quick tip for removing your tranny that will male it a whole lot easier....Remive the trans from the bell housing first, then the bell housing from the engine. It makes it so much easier to get to the top bolts. Good luck.
Old Mar 2, 2003 | 02:30 PM
cy's Avatar
cy
Thanks for the advice.
I found an install article for replacing a clutch, and it seems to be what i need.
