shifting problem
Old Jul 22, 2003 | 10:42 PM
marcus's Avatar
Default shifting problem
i just installed a midwest 3000 stall with a 2.5str..my question is when the tranny shifts into 2nd and 3rd gear it bounces off the rev limiter and i have to let off the gas to let it shift..do i need to set the shift points to 5500? cause right now it shifts at 6000. and will hpp3 solve this problem? thanks for any help...
Old Jul 23, 2003 | 12:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: shifting problem
Make sure your trans fluid is full, but yeah you could use the HPP3 to fix that. I would not lower shift points to 5500 you will go slower, but I would raise the rev limiter to 6100-6200 and make sure that's shifting at 6000 and not higher.
Old Aug 4, 2003 | 05:41 PM
98tata's Avatar
my stock ta dose this any answers why tranny fluid clean and full
