moser 12 bolt install?
2 qts non-synthetic gear oil 80-90wt
1 tube of limited slip additive
2 3" muffler clamps for the sway bar bushing mounts
8 nuts for the special T-bolts (included in the Moser kit) forgot what size 3/8 or 7/16??. Why don't they just include these nuts in their kit??
1 hex head wrench 1/2?? for the oil fill plug
1 piece of 12" hose for the axle vent 3/8 ID??
8 ea - Housing End T-Bolts 2 ea - Inner Housing Seals 2 ea - 1/8" Shims
You Will Need These Items For Your Install
8 ea - 3/8" - 24 nuts & washers for the housing ends Gear Lube - Approximately 3 quarts Rubber or plastic vent hose/line
**If you are using a Limitied Slip Differential, you will need to add Limited Slip Additive to the fluid. **Other small parts may be needed based on each individual application. Please read furtherunder the particular application that fits your need.
ADDITIONAL INFORMATION
Venting
Your M/E Bolt-In housing needs to be vented for proper operation. A hole has been provided in the tube and a 1/4" pipe thread air line fitting has been included. After installing the fitting, run a rubber or plastic line from the fitting to a suitable location on the frame. Allow enough line to compensate for suspension travel. MAKE SURE THE END OF THE HOSE IS HIGHER THAN THE VENT HOLE OR YOU WILL LOSE FLUID.
F-Body 12 Bolt - 1982 to Present Camaro & Firebird
Your new housing has larger tubes than your stock rear. Your stock sway bar mounts will probably not fit the tube. You will need to get muffler clamps made to fit either a 3" OD tube and adapt the sway bars to them or to get aftermarket sway bar adapters
Your new Bolt-In housing does not have the tabs on it for attaching the brake lines. The most common and easiest way to secure the brake lines is with cable ties.
If you purchased your 12 Bolt with a Performance Rear Cover with the load bolts to support the main caps, it may interfere with your panhard bar. If it does, simply grind the head of the load bolt for clearance.
Don't forget the paint <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
