Anyone use a TP4400 with 3.23s?
Old Jul 24, 2003 | 07:49 PM
JaSSon's Avatar
Default Anyone use a TP4400 with 3.23s?
Wanting a little more converter and not to change gear.If you had this setup what were your results? BTW I will do heads later. Thanks Jason
Old Jul 25, 2003 | 05:39 AM
WILWAXU's Avatar
Default Re: Anyone use a TP4400 with 3.23s?
12.67 before 12.07 after... with a nearly stock car.
more specifics of the setup are here: http://www.geocities.com/wilwaxu/about.html#formula
Old Jul 25, 2003 | 07:47 AM
Ragtop 99's Avatar
I had the TP4000 with 3.23s. I forgot the exact results but I needed more gear given my car's weight and tire (26x11.5x16).
Pretty loose but very killer on the street.
Do you have edit? Higher part throttle shift points will eliminate some looseness.
Old Jul 25, 2003 | 11:45 AM
Jorday's Avatar
I have the 4200 with 3.23 gears. Best 60 ft time has been 1.62, full race weight, tires spinning a bit. I really like this converter, but now wish I would have gone even bigger.
Jordan
Old Jul 25, 2003 | 07:28 PM
WILWAXU's Avatar
Jordon,
Get some 3.73's.. you'll pick up a little on bottom.
Old Jul 27, 2003 | 10:14 AM
JaSSon's Avatar
Hey WILWAXU, when you went from the 3.23s to 3.73s with the TP4400 what were your gains?
Old Jul 27, 2003 | 03:35 PM
Ragtop 99's Avatar
I gained a little less than .1 when I made the switch (I had the PT 4000 at the time).
