shift points and rev limiter for 373 with 3600 2.0 str
Old Jul 24, 2003 | 08:49 PM
smokeyalater's Avatar
Default shift points and rev limiter for 373 with 3600 2.0 str
as stated, what shift points to use? car is pretty much stock otehrwise
Old Jul 25, 2003 | 08:18 AM
SuperZ28's Avatar
Default Re: shift points and rev limiter for 373 with 3600 2.0 str
when I had my 4000/3.73 combo I had my settings as follows: this is with stock cam and valvetrain
1-2 shift @ +3
2-3 shift @ +2
3-4 shift @ +2
rev limiter was set @ 6300
shift firmness was @ 50%
this was all done with a HPP3
Old Jul 25, 2003 | 08:19 PM
Ragtop 99's Avatar
6000 is fine for your shift points. I went to 6200 after I had headers etc.
Old Jul 27, 2003 | 08:24 PM
Jpr5690's Avatar
just to fill ragtops post in mmore your already a bit over 6000 shifts with 3.73 if your auto i did a post a while back about a4 shift points if you wanna figure it out id guess your in the 6100 range personally a limiter of 6400 and shifts at 6300 would net you the best runs (imo) but i keep my car at stock like shifts cause its too contversial to go past that---good luck!
Old Jul 27, 2003 | 08:27 PM
Jpr5690's Avatar
ragtop did you shift at 6200 with stock valvetrain if so how did it hold up i was shifting at 6300 for a while but i got paraniod and put it back down
