tranny issue
Old Mar 23, 2008 | 01:50 AM
00formLs1's Avatar
Default tranny issue
well i couldn't help myself and used my n20 the other day on the way home and well, the car shifted fine on the 1-2 but on the 2-3 it hit the rev limiter.
ever since then if i floor it the rpms shoot up and bounce off the limiter and it will not shift under full throttle. at part throttle it will shift but only at higher rpms. mods in my sig, i was only shoting a 50 dry with a window switch, converter is a fuddle 3500 2.0str. does this sound like a converter problem?
Old Mar 23, 2008 | 02:46 PM
00formLs1's Avatar
anyone? tried a search
Old Mar 23, 2008 | 03:14 PM
performabuilt's Avatar
LS1Tech Sponsor
Are you getting any check engine lights and when ou say shifts at HIGH RPM explain in more detail please under normal driving ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 23, 2008 | 03:18 PM
00formLs1's Avatar
i had a light from an o2 that was out but i will check again tommarow.
under normal driving the car will shift but it is around 3500-4500rpms once the car shifts in to overdrive it drives normal. if i give it gas to try and get it to down shift it won't, the rpms just climb and will bounce off the rev limiter.
Old Mar 23, 2008 | 03:42 PM
LS1Tech Sponsor
check those codes again and let us know what you find .
__________________
Call 888-744-6542
Old Mar 23, 2008 | 04:08 PM
ls2pontiac's Avatar
Self-Admitted Scammer
probably one of the clutches failing. that started happening in my old trans after i revved it up to 3000 in neutral then dropped it into drive a few times
Old Mar 25, 2008 | 02:49 AM
00formLs1's Avatar
no codes came up, i am going to change out the filter and she how the fluid looks.
