what stall to buy?
Old Mar 27, 2008 | 12:24 AM
BLACK 97 SS's Avatar
Default what stall to buy?
so i have a 97 ss only mods done to it is full exhaust including lt's 4.11 gears and a 125 shot wet.. what is the best stall i can get for this type of setup because i was thinking of going with a 2800 or 3000 any input would help....
Old Mar 27, 2008 | 02:48 PM
00cls1camaross's Avatar
sack up, get a 4000 you will not regret it
go big or go home
"having a small stall is like having a small dick, every time you use it, you wish it was bigger"
my fuddle 4200 hits hard, i dont regret getting it that big at all! just get lock up in 3rd gear at 28 and 4th 33 and you will be set for traffic and for cruising.
Old Mar 27, 2008 | 02:56 PM
ta_06374's Avatar
Its a lt1...I would go with a 3k.
Old Mar 27, 2008 | 03:00 PM
Wsteun's Avatar
LT1's can get away with running a lower stall.
Old Mar 27, 2008 | 06:19 PM
bad2000z's Avatar
VIG 2800 dumdumdum.
Old Mar 27, 2008 | 07:59 PM
jp74's Avatar
[QUOTE=00cls1camaross;9020001]sack up, get a 4000 you will not regret it
go big or go home
Old Mar 27, 2008 | 10:21 PM
StealthFormula's Avatar
as said LT1's dont require as large a stall as LS1's do and a 4000 wouldnt be a good idea. With the Nitrous your not going to want something quite that large, the shift extension would be practically where your shifting when on the spray. Id give Yank a call they were very helpful to me and advised me to go the 3600 route with my 6400rpm shiftpoint and plans to run a 150 shot.
