how built is my th350 gonna have to be??
its going to be somewhere around
4.8 cnc heads
23x./ 23x. 612./612. on a 110 maybe lower
i am looking for atleast 10.80's out of it, how built is this th350 gonna have to be? and also what kinda converter should i go with?
The converter choice is going to depend on how much HP/ what diff gear ratio (to simplify it). I've seen some rough formulas for stall/STR choices on converters for given choices, but it's all pretty subjective. Check out your local drag strip and ask a lot of questions! Car folks like to talk performance once you get to know them.
I would recommend blue-plate clutch with Kolene steels, trans brake, deep cast aluminum pan, and after market drum/sprag assembly (all TCI stuff). <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> This set-up should not give you any trouble and will be reliable (with a trans cooler). <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Kevin Steele
