need automatic advice
Old Jul 26, 2003 | 10:41 PM
Lt1plus's Avatar
Default need automatic advice
Okay i am not used to automatic cars. I have a 4 sp manual camaro and six speed camaro. I usually only race on the street. I was thinking about trading my lt1 on a A4 ls1 car. I am looking at a couple 99's. I was thinking automatics are more consistent. Are automatics any easier to hook up? If I trade again I will not have a whole lot to put into the car, but car craft stated in the sept issue that a converter added a half second or more in the 1/4. That sounds like my first investment. How much did you guys gain with a converter? Any advice would greatly be appreciated.
Old Jul 27, 2003 | 02:36 AM
Miriah's Avatar
Sponsor
Default Re: need automatic advice
On the track in my 01 LS1 Formula I went from a 13.4 to a 12.41 with a lid, catback and a 2800 stall Pro torque converter. I used nittos as my tire to hook.
A4 is better for racing but from what I hear M6 is more fun. I"m not a street racer so I can't answer any of those questions.
Miriah
Old Jul 27, 2003 | 09:44 AM
Lt1plus's Avatar
thanks
Old Jul 27, 2003 | 03:43 PM
Ragtop 99's Avatar
off the line racing is much easier with an automatic. A good converter and nittos will make you very quick. An M6 is better if you race from a roll.
Look for an A4 that has 3.23 gears. "GU5" option code or "performance axle" if the seller saved his sticker.
Old Jul 27, 2003 | 07:50 PM
Miriah's Avatar
Sponsor
Yup, he can even find that gear option code on the drive side door. When you open the door on the door jam there should be a white sticker w/all the option codes on it. Just look for the GU5 one.
