i need help guys
Old Mar 31, 2008 | 09:19 AM
pozesd99''s Avatar
Default i need help guys
i have a 4l80e on my car which is a 402 ls2 stroker with a single 88mm on 18psi with a 75 shot. im expected to make about 1000rwhp and need a converter that will handle about 1500hp. i bought a hughes 4000 stall converter, doyou think it will last?
Old Mar 31, 2008 | 10:12 AM
Gilbert@Ace Racing's Avatar
If the Hughes unit was spec'd out for your combination you should be fine. Run it and see what happens.
g
Old Apr 1, 2008 | 06:31 PM
pozesd99''s Avatar
bump
any more insight would help
Old Apr 1, 2008 | 06:42 PM
caldercay's Avatar
Call Dave at Yank and ask him his thoughts.
Old Apr 1, 2008 | 07:23 PM
Dragkid1917's Avatar
thats one nasty goddam combo you got there man. Since you bought it idk anything about huges but if they say itll last it prolly should. I too would call vig or yank for what you would need to handle that h/p and compare the converters (ie cluthes inside and other **** like that)
Old Apr 1, 2008 | 07:33 PM
pozesd99''s Avatar
ok ku thanks guys and by the way the tranny is a 4l80e.
