Gear Vendor's OD unit
Old Mar 31, 2008 | 05:18 PM
mreed72's Avatar
Default Gear Vendor's OD unit
Does anybody here have this unit in there car with a turbo 400.What are the pros and cons of this unit and what kind of modification's will I have to do to install this.I will be putting this in a 2000 model Tran-AM.
Old Apr 1, 2008 | 03:51 PM
MARO-KEEN's Avatar
LS1Tech Sponsor
I think your first issue will be torque arm clearance. We've put one in a viper with a glide but, i've never seen one in an f body.
Old Apr 1, 2008 | 04:30 PM
Phate's Avatar
I have one on my car...there is no TA clearance issues unless you have a front DS loop built into the TA (a la spohn). I had to cut my front DS loop off...
I'll look to see if I can find some pictures.
Old Apr 1, 2008 | 05:43 PM
DanZ28's Avatar
I would have thought you would need at least a short mount TA and a really short DS.
How do you like the GV unit driving around and at the track?
Old Apr 1, 2008 | 09:23 PM
mreed72's Avatar
Thanks for the info. Phate did you get better 1/4 mile time after you installed it. If you have some pic's that would be great.I have a BMR TA on mine will that make any difference on clearance than the sophn.
Old Apr 1, 2008 | 09:32 PM
supernaturalta's Avatar
Are you aware of what those units cost?
http://www.gearvendors.com/aghr3s.html
Phate might be able to fill you in on that, but I know they definitely aren't cheap.
Old Apr 1, 2008 | 09:42 PM
mreed72's Avatar
yes I have been checking out there website and yes they are expensive. But i would like to have OD.
Old Apr 2, 2008 | 12:38 PM
Phate's Avatar
To tell you the truth, after things went together I ended up changing combinations and the car has been sitting a while. I am planning to ship it off and get it finished, but that is maybe 3-4 months out.
So, no track impressions with the GV...but it works as advertised and you can set it in auto mode so that it clicks on @ 50 or so or use it in manual mode.
The driveshaft is REALLY short, I had my Denny's re-sized to fit and it works well. Not sure how the BMR TA is different then the Spohn unit, so I can't comment as to issues there. Sorry that I can't offer more info...but the install was actually pretty simple and pain free.
Old Apr 2, 2008 | 12:57 PM
SVT THIS's Avatar
You want a tough trans and OD go with a built 4L80e. I looked at the gear vendor until I read about the 4L80e.
Old Apr 2, 2008 | 01:04 PM
LT1-DAN's Avatar
I have seen a few in 1st gens, but never in 4th gens.
Old Apr 2, 2008 | 01:10 PM
night ryder's Avatar
if you drive the car alot, it will pay for itself in no time.
Old Apr 2, 2008 | 01:54 PM
stoverz28's Avatar
+1 on the built 4l80e. If your set on this route, my uncle has one of these that he used behind a muncie 4 speed (not sure if same as th400), in a 67 chevelle. It probably doesnt even have 1500 miles on it (it still wasnt enough OD for him and the 07 power tour).
Old Apr 2, 2008 | 01:55 PM
stoverz28's Avatar
Pm me and ill get you a price if you want.
Old Apr 2, 2008 | 01:57 PM
LT1-DAN's Avatar
Muncie is a manual transmission.
Old Apr 2, 2008 | 05:13 PM
mreed72's Avatar
thank's for all of the info guy's now all I have to do is make up my mind if I want it or not.Sounds like it is what I am looking for.
Old Apr 2, 2008 | 10:10 PM
stoverz28's Avatar
Im not sure on the difference (bolt pattern, input shaft etc) between a GV OD unit for a th400 and one for a muncie. lol Im not that dumb man.
