700r4 spacer question
Old Mar 31, 2008 | 05:55 PM
tsx153's Avatar
Default 700r4 spacer question
got my spacer today and tried to put it on and the spacer will not go over the pin on the back of the crank? i thought the spacer went on first then the flexplate... does that pin need to come out or something? and the spacer has 2 offset holes but both of the holes are tapped. whats this for? i figured the pin would go in one of them but they are tapped for like a bolt. help me out please!!
Thanks
Shaun
Old Apr 1, 2008 | 06:36 AM
tsx153's Avatar
no one has an answer for me?
Old Apr 1, 2008 | 08:37 AM
TTS's Avatar
TTS
What spacer? Picture?
Old Apr 1, 2008 | 10:03 AM
FLT's Avatar
FLT
The spacer goes on after the flex plate. TTS welcome to the boards. This spacer that the user is referring to is a converter pilot spacer. This is used when the converter is not built for an LS1 engine. Vince
Old Apr 1, 2008 | 11:12 PM
TTS's Avatar
TTS
Thanks.
I thought it may be a pilot adapter, but I try not to assume anything.
