So confused
Old Apr 5, 2008 | 10:35 AM
z28_YOU_HO's Avatar
Default So confused
Alright well i got my car out of the shop yesterday..swapped over to a new 4l60e and put my TCI 3500 stall in..but for some reason my throttle is sticking now..only seems to do it when im in gear though..Ill just nail the gas for a second and it will keep going..Not a full throttle stick though, just enough to keep the car accelerating very slowly...but ill be in park and ill rev it but it wont do it...When it happens though ill pop the car in neutral and it will continue to rev.. So i dont think it would be the tranny..???? Im just confused as hell could this be a tranny problem? And what should i trouble shoot to fix this?
Old Apr 5, 2008 | 11:19 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like a possible isue with the throttle cable or even some electronics issue having to do with the IDLE AIR CONTROL solenoid or the PCM. I have heard some people say they have had issues with idle after a small diameter stall was put in. Are you planning to have the car tuned for the stall if so they will likley be able to work it out during the tune, There is no trans issue I can imagine that would cause high idle or a stcky throttle.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 5, 2008 | 12:31 PM
z28_YOU_HO's Avatar
alright great didnt want anymore problems with that.. im gonna get it tuned after the cam..should i mess around with my programmer?
