Redline trans fluid
Old Jul 29, 2003 | 02:57 AM
4thGENRETARD's Avatar
Default Redline trans fluid
I'm thinking of switching to Redline trans fluid.Is it worth it? Should I use D4 or ATF? I forgot which for 4L60E. On D4 it says 33% more viscosity and ATF 50% more than GM fluid.
Old Jul 30, 2003 | 06:43 AM
Default Re: Redline trans fluid
Any comments Pleaaaaase!
Old Aug 7, 2003 | 06:34 PM
Cheatin' Chad's Avatar
I use it in my modded 2000 GTP. It works well. The car shifts better especially in cold weather. I am planning on filling my TA with it when I put in my converter. Use D4 ATF if you run the card in the cold weather. If you aren't driving the car when it is freezing out use the high temp ATF.
