th400 2 power glide swap
for stock vs stock ratios. the 1.76 is stronger but heavier. the 1.82 is lighter but weaker.
if its big power, straight cut gears should be something to look into. I have heard that 1.80 is a great ratio.
how much power are you planning on making?
The whole idea of building one of these is very relative to your budget. I am sure we could put a build together for your needs.
g
