Front Pump Install..
IF so, how hard is it to change? Is it something easy to do, once the tranny is out? Looking at the pictures it looks like a few bolts holding it in.
Has anyone done this? Pointers?
1) The pump will not go back the trans
2) The seal on the stator will be cut
You will want to tear down the tranny to clean any metal out of it (there may not be any).
When carefully reinstalling the pump, use Vaseline to lube the seals on the pump stator.
Kevin Steele
