Shifting the auto with a stall
Old Apr 11, 2008 | 11:49 AM
th3brandon's Avatar
Default Shifting the auto with a stall
ok well i have a 95 trans am it is a 2.73 car....i just installed the 3600stall and 3.73...the car does not have first gear u can put in manually...so i cut a ruuber *** off and made it so i can put it down in 1st. now with the stall the computer makes it shift when i have it down in 1st to 2nd and back to first again by itself could a tune fix it. what should i do??????
btw: first gear would to that sometimes with the 2.73 and stock stall but not as much... when everything is working right it was nasty gear... i just dont know if this is bad for the transmission or not
Old Apr 12, 2008 | 01:37 PM
th3brandon's Avatar
TTT
Old Apr 12, 2008 | 01:40 PM
FirebirdFormula95's Avatar
you could just be loosing first gear for a while i didnt have first gear and it just turned out to be bad sensor
