What are possible signs of when a converter takes a dump
Old Mar 11, 2003 | 05:18 PM
sited12's Avatar
Default What are possible signs of when a converter takes a dump
Just would like to know so i can figure out if the converter or the tranny is broke. The converter is in there and the tranny pump spins but i have no gears. The converter spins but the car neutraled out. Linkage is fine.
Old Mar 11, 2003 | 08:58 PM
99taws6's Avatar
Default Re: What are possible signs of when a converter takes a dump
How did you test to see if your tranny pump is ok?
Old Mar 11, 2003 | 10:26 PM
sited12's Avatar
Chuck from FLP said to fill it with fluid and check it. Then start the car and if the fluid level drops then the pump is working. So we tried it and it confirmed it. Also there is a hole on the driverside where you can pull a plug out and screw in a pressure gauge and at idle in park it is suppposed to be 100 PSI.
Old Mar 12, 2003 | 06:32 PM
99taws6's Avatar
well, my front pump was bad.. Both the tabs were sheard off of it.... The tranny is being rebuilt and a new pump installed.
How do you plan on testing a converter?
