stall for turbo
Old Apr 14, 2008 | 02:36 PM
john563's Avatar
Default stall for turbo
What size stall for turbo..Currently I'm N/A and have aTCI ssf3500stall,but will be going turbo soon and wanted to know what size to go with
thanks
john
Old Apr 14, 2008 | 03:04 PM
Circle-D's Avatar
thanks
john
I would suggest something in the low 3000 range, depends on how fast the turbo spools up at. You could probably lock the converter up as well with the extra torque, so also look at multi disks.
Chris
Old Apr 14, 2008 | 06:03 PM
john563's Avatar
Chris
Its a 70mm turbo. I dont plan on buying a new verter til late summer/fall when I install the turbo. can you PM some prices for a multidisc. lets say 3200stall
Old Apr 14, 2008 | 07:45 PM
John_D.'s Avatar
I have been running a TCI 3000 with a 70 rear mount.
When I flip the switch from low boost to high, in the middle of a 3rd gear pull, the scan log shows the rpms jump by about 500.
I'm stepping up to a 3400 multidisc from Circle D. The 3400 to help it get out of the hole, and the multidisc so I can lock it up after it gets going.
