need a full rebuild "KIT"
Old Apr 19, 2008 | 01:42 PM
SUPER_CHEVY's Avatar
Exclamation need a full rebuild "KIT"
just wonder if there is a place i can get a full reburied kit for my 4l60e..
cuz im tired of making a parts list and bay each part separately
the project is street racing car with H/C combo, full bolt-ons and 100 wet shot with ss3600 stall,, the power will be around 380-400 with out NOS
can you help me to find a place to buy it all in a kit??!!
Thanx in advance
Old Apr 19, 2008 | 01:56 PM
9000th01ss's Avatar
Most of the transmission sponsors here sell kits, look at the list on the right.
Personally I like to pick and choose my own stuff but the sponsors here are the best you'll find in any forum, and they put together kits using parts combinations they know work.
AND most will help you here if you have a problem.
Look for ACE, Finish Line Transmissions, and Performabuilt.
Old Apr 20, 2008 | 02:16 PM
ok guys i found a kit, but i just have some question..
Do i need to add this part?!
-TransGo Separator Plate
-GM Reverse/Input Drum
-Manifold Pressure Switch
Do i need them for the build??!!
Old Apr 22, 2008 | 01:34 PM
PBA's Avatar
PBA
Do I need to add this part?
-TransGo Separator Plate? Is yours damaged? If damaged from the check *****, then replace it.
-GM Reverse/Input Drum? Is the band in your transmission burned?, or if the drum is dished where the band rides. Then you will need one?
-Manifold Pressure Switch? How many miles on the unit? High miles, yes. Is the transmission fluid burnt? If yes, then replace it.
Old Apr 22, 2008 | 01:42 PM
Gilbert@Ace Racing's Avatar
I am pretty sure that the Sponsors here do not sell complete kits. I have read where Frank does not, I do not and in a conversation with Vince a month or so ago he mentioned that they were getting out of suppling parts to DIY builders.
However, Dana at Pro Built does... PBA here. He will set you straight I am sure. Good guy IMHO.
g
