trans. filter seal ?
Old Apr 25, 2008 | 06:53 PM
04goatman's Avatar
Default trans. filter seal ?
I changed my transmission filter 04 my 04 GTO but i didn't replace the new trans. seal that the trans. neck locks into inside the trans. because I didn't have a tool for this and being my 1st time doing this I didn't want to damage anything trying to get it out.I used the old one, Is this ok ? Would this cause possible problem down the road ?
Old Apr 25, 2008 | 08:16 PM
FLT's Avatar
FLT
I personally feel if the seal fits well on the filter, leave it alone. I have seen guy's do more bad than good in this area. I always replace this seal at the time of the overhaul and I think with your car being an 04 your probably ok. Vince
Old Apr 26, 2008 | 07:11 AM
04goatman's Avatar
[QUOTE=Vince @ FLT;9237600]I personally feel if the seal fits well on the filter, leave it alone. I have seen guy's do more bad than good in this area. I always replace this seal at the time of the overhaul and I think with your car being an 04 your probably ok. Vince
Thanks for your input, Should i change the gasket out on my next 25,000 miles filter change or leave it ?
Old Apr 26, 2008 | 07:21 AM
FLT's Avatar
FLT
As long as the filter has good resistance on the seal it should be fine.
Old Apr 26, 2008 | 05:51 PM
jsteele90's Avatar
yeah mines been stuck in there for a few years now. ive done about 4-5 filter changes since then and its fine.
