have a problem need help
well im sure ive fried my trans , the fluid is black , shifts good though but at low load i am getting a mean shutter if i goose it it pulls through it brand new tires engine not throwing any codes car has 40,000 on it with nitrous , trans is stock ls1 camaro anyone know about this i figured it would slip if it was going bad but u joints checked out , pinion angle is acceptable and engine is fine why the violant shutter ? need help
What he meant to say is.......
well im sure i have fried my transmission.The fluid is black but it still shifts good . But at a low load i am getting a mean shutter and if i goose it it pulls through the shutter. It has brand new tires and the engine is not throwing any codes. The car has 40,000 on it with nitrous.The trans is the stock ls1 camaro trans. Anyone know anything about this, i figured it would slip if it was going bad. The u joints checked out, pinion angle is acceptable, and engine is fine. why the violent shutter? need help
This might help people understand what you are trying to say. If you want help you should put more time into making a post, that makes sense to people that read it. I don't have any suggestions that would help you but at least people can understand what you are saying now.
thanks , and sorry , i was in a hurry basically , Ive got a mean vibration that isnt , engine, tire,or suspension related. ive never had a trans shutter on me though , its a violant shutter, just wondering if anyone has heard or had an experiance in such a thing , thanks
It does indead sound like the trans is done and a slipping clutch can shutter/chatter
__________________
