Problem after converter install
Old Apr 27, 2008 | 08:29 PM
DMSZ28's Avatar
Default Problem after converter install
So after my converter install the tranny likes to puke fluid out of the dipstick tube when i turn the car off . Anyone have any thoughts or ideas what could be causing this???
Old Apr 27, 2008 | 08:50 PM
performabuilt's Avatar
LS1Tech Sponsor
Are you sure the trans is not overfull. And did you try and hook anything up to or damage the vent tube on the top of the trans just behind the bell housing. If its puking fluild out the dipstick that means air cannot get out of the vent.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 27, 2008 | 08:57 PM
DMSZ28's Avatar
The tranny is not overfilled. I made sure to be careful with the vent tube, but I will double check it to make sure. Any other thoughts?
Old Apr 27, 2008 | 09:36 PM
DMSZ28's Avatar
The weird thing is it only pukes it out when i turn the car off, not while its running.
Old Apr 27, 2008 | 10:03 PM
LS1Tech Sponsor
That really sounds like the vent tube is blocked
__________________
Call 888-744-6542
Old Apr 28, 2008 | 08:34 PM
ponyeater01LS1's Avatar
ill second that check the vent tube i had the same prob it do to me once, stuck my hand up to check and it was pinched
