VSS not seen by ecu
Ecu is not seeing speed signal, and therefor not shifting the auto tranny into the next gear. I traced the yellow and purple wire down to the speed sensor and they are fine no problems there. Replaced the speed sensor, same problem. ECU is not seeing VSS signal. Does anyone have any ideas what could be going wrong? Are there any other wires that tie into the VSS? I have the green white stripe (vss output) going into a dakota digital and it doesnt seem to be getting signal either. Anyone have any ideas??? please help.
updated. Changed ecus, doulbe checked wiring. Tested and replaced VSS... still no signal being seen by the ecu, does anyone have any ideas?
guess i should have read closer don't know how I didn't see that.
My tranny guy rode along with his DX box in his lap and found the PCM was reading the vehicle speed up and down like crazy. The problen was that my Autometer Spedo was wired into the VSS HIGH signal from the speed sensor on the tranny. Rewire the spedo to the VSS out from the PCM. On my 2002 harness it is C2 pin 50.Bill
