Maybe yall can help...
Old Aug 5, 2003 | 08:15 PM
TransAmDriver's Avatar
Default Maybe yall can help...
Last night I pulled the wrong valve out underneath when doing my shift kit since the Trans-Go instructions didnt even tell me which one, and I wasnt paying attention and pulled out the one that goes above the solenoid with the exposed copper wire. The BIG problem is as soon as this happend it fell out with the 1 spring and I dont know how it goes back in. Here are the pics, one is a pic of where it went and the other is a pic of the valve.
Thank yall for ANY help!
Old Aug 5, 2003 | 08:35 PM
Pete2k_Z28's Avatar
Default Re: Maybe yall can help...
My valvebody is sitting in a drawer in my garage right now. Give me a few minutes I'll pull it apart and check it out for ya
I don't have a digi cam but I'll try and explain it as best I can.
Sit tight...
Old Aug 5, 2003 | 08:50 PM
Pete2k_Z28's Avatar
Could you give a better description of where on the valvebody that piston is? Mabey a pic of the entire valvebody and you can Pchop or even tell me wich one it is? The one I pulled does not look like that nor have a circlip and washer, and I don't feel like pulling my entire valve body apart right now.
Hopefully I'll see your reply tonight and be able to reply.
Old Aug 5, 2003 | 09:13 PM
I found out what it was through a gracious person on email. It is the TCC control valve. I goes back in skinny end first with the two springs ontop(one was still in the hole) and then the little metal thing goes on the bottom. Thank you so much for taking the time to do that for me!
Old Aug 5, 2003 | 09:46 PM
Pete2k_Z28's Avatar
No problem! I wish I could have had your ??? answered sooner.
Good luck with the rest of the install!
