Code PO756?
Old May 24, 2008 | 11:24 AM
RENE'S RAGE's Avatar
Default Code PO756?
Car not shifting into third, acts like its bouncing off the rev limiter, just had the car tuned. What does code PO756 mean? Any help would be appreciated. Thanks George
Old May 24, 2008 | 11:36 AM
performabuilt's Avatar
LS1Tech Sponsor
P0756
Shift Solenoid B Performance or Stuck Off/
2-3 Shift Solenoid Valve Performance
This could happen because the solenoid is bad or it can also happen if the 3-4 clutch is bad . Another possible reason is with a high stall over 3000 normally the PCM becomes confused and does not thing the shift has actually taken place.
https://ls1tech.com/forums/showthread.php?p=8993762
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 24, 2008 | 05:32 PM
Thanks Performabuilt, great article. The car has a 3800 Vigilante stall, I put H/C package on this winter. The car ran fine after H/C package, car shifted fine. After I took it to get it tuned thats when the 2-3 shift started acting up. My tuner thinks its the 2-3 shift solenoid. I am thinking about replacing the solenoid myself. What all is involved, after I pull the pan can I see the solenoid? Thanks Again George
Old May 24, 2008 | 07:32 PM
LS1Tech Sponsor
Its realy simple there are thee side by side A and B the have clips holding them in , One will feel like its just loose kinda floppy this is the B solenoid The A solenoid will have some spring presure behind it, Generally I suggest changing them as a pair
__________________
Call 888-744-6542
