please help
Old May 28, 2008 | 09:49 PM
Rickys S/C Z28's Avatar
Default please help
i had my 4L60E built in Nov 07 the shop that did it is a good shop(i was living in hawaii at the time ARMY not rich) the shop had built me a 700R4 the year before in another car and it was GREAT so i dont think they did anything wrong this time, but hear is the deal, i have been driving the car hard most of the time and had NO PROBS what so ever, then about a week ago i was on the highway not driveing hard at all and lost ALL gears? i checked the fuild all is good, i have not looked at the car cents it happend because im in SC right now for school and the car is in KY, the car has a hughes 3800 stall in it, the fuild does not smell burnt, is there anything i can check befor i pull it out and send it back to hawaii?? the guy stands behind his work i called him and he said send it back and he would fix it for free but if there is something i can check out befor i pay to ship it then id lie to see. sorry this is long but i just wanted to give some back ground, thanks for any and all help
Ricky
Old May 29, 2008 | 10:08 AM
9000th01ss's Avatar
You could check line pressure. Does it have reverse? If it's got normal line pressure it's probably a mechanical problem, maybe a forward sprag.
Old May 29, 2008 | 10:15 AM
Gilbert@Ace Racing's Avatar
Checking line pressure can be difficult if you are not tooled up for it.
My recommendation would be to spend a few dollars to have it inspected by a reputable shop near you. It might save you the time and trouble of pulling it and shipping it.
Good Luck
g
Old May 29, 2008 | 10:19 AM
EDS01SS's Avatar
sounds like the same thing that happened to me. My issue was the front pump grenading itself. My transmission was also built for performance and was from a reputable shop.
Old May 29, 2008 | 10:43 AM
performabuilt's Avatar
LS1Tech Sponsor
A quick check for pump failure would be to remove a line from the cooler and start car if fluid flows pumps working if not then theres your problem.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 29, 2008 | 05:11 PM
thanks for all help ill have my brother do the things that you guy have said and ill let you know
