Converting to a T400, couple of questions
Assuming that not everyone has a wideband 02 and a laptop with EFI Live or similar, we can use these "Indian Methods" and get a fair idea of how much slippage there is with an unlocked vert in a TH400/350. Yours was only 200 RPMs over what the math made it to be. Now, pddye was using his stock tach, so we can throw that number out, assuming he had a time-slip with 125 mph on it, using the calculator with no slippage he would have only been taching 5595. If he was taching a true 6800 RPM with his setup, that would have been 152 mph (assuming no slippage). We can use Dan's amount of slippage and Mr. Pddye might have been taching 6000 + 200 = 6200 @ 125.
This is not scientific of course, but we know there is X number of RPM over what a normal 1 to 1 calculator tells us, as if we all had 6 speed trans cars.
Hopefully the "OP" can garner some rough idea from this info. Good discussion guys.
Using the OP data, he would have almost 22% slippage, not very efficiant at all. Of course thats using the 6800 RPM data.
Between that one and the one I posted earlier in the thread, you should be able to calc just about any combination of setups. Good info.
