Single or triple disk, and converter math
Car is a C5 with a vortech t-trim built engine, with a break in tune and 12lbs of boost we saw 614rwhp. Our plan is to increast the boost to 14lbs add meth injection some more timing put on a 90/90 (using ls1 right now) etc at wot to make around 700rwhp.
I want to stay in third gear at the end of the 1/4 using 3.15 gears and a 26" tall tire.
With no converter slip at 6500rpm that figures out to 147mph.
What would my mph be if I use a single?
Or should I just use a triple and not lock it up?
What would a normal slip %be?
Peter
http://www.tciauto.com/Products/Tech...culators.asp#4
A good triple disc converter is just really good insurance and a great track/tuning tool for serious power adder cars. Do it right the first time and with your set up, you probably already know that.
Good luck!
Chris
Chris
