vss problem
Old Jun 4, 2008 | 09:09 PM
67LS3's Avatar
Default vss problem
i have the gm performance ls3 with the gm perf harness/ecm installed in a 67 camaro. my issue is the new gm harness is pinned for the later model speed sensor(small) and my built trans has the early(big) sensor. My trans guy says the sensors are the same? is the output signal the same? the output shaft with reluctor is the same in the trans for the two. is it just a wiring connector issue or am do i have a bigger problem?
Old Jun 4, 2008 | 09:12 PM
performabuilt's Avatar
LS1Tech Sponsor
Its just a wiring connector issue swap the pigtail
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 4, 2008 | 09:17 PM
67LS3's Avatar
thanks. i was almost certain it was just a wiring connector issue due to the trans output shaft being the same. you rock. i feel much better. i will try to find the gm connectors to make a pigtail to not modify my gm perf harness. is that possible?
Old Jun 4, 2008 | 09:59 PM
LS1Tech Sponsor
You can just splice the correct one in
__________________
Call 888-744-6542
