Converter? for 4L60E in light car
They have some good info on their site.
Also check with the site sponsors to the right for Converter info.-------------------->
I'd love to see some pics of that swap and some times on it when you get it goin. Should be alot better than the Monster Miata 5.0's if you do things right.
Good Luck!
How do you keep the weight from messing up the suspension and handling?
since you will easily overwhelm your tires, you can go small in the converter stall speed and use a low STR. I suggest a 3000 - 3500 stall because you'll want the longer shift extension for good power from a roll.
BTW, we have a conversions section for people doing swaps. I hope you'll keep us posted and post your results in there.
Ok I found out what STR is.
I would call Mike at Yank, do to the weight difference the converter will stall different than in a F-body.
BTW: I want one!
How much is the conversion kit (not counting the engine)? Custom headers available?
JB: True stall will not be changed by weight; flash stall will be.
