4L60E truck???
Old Jun 17, 2008 | 10:20 PM
juicedls1's Avatar
Default 4L60E truck???
What r the differences (if any) between the f-body 4L60E and the truck
4L60E? I can get a good deal on a f-body tranny with converter (BTE) and i was wondering if it would bolt up in my truck(00 Silverado 2wd 5.3l)! Thanks n advance!!!
Old Jun 17, 2008 | 11:42 PM
performabuilt's Avatar
LS1Tech Sponsor
You will need to change the shifter linkage rod but other than that its a swap
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 17, 2008 | 11:56 PM
STALL UP's Avatar
the tailshaft housing but your putting it in to a truck so it wont matter if it has 3 holes in it for the f-body torque arm
Old Jun 17, 2008 | 11:59 PM
LS1Tech Sponsor
Hes going from f body to truck
__________________
Call 888-744-6542
Old Jun 18, 2008 | 10:09 PM
juicedls1's Avatar
K guys thanks for ur help! I was makn sure the input/output shafts were the same, that was the only thing i was ify about.
Old Jun 19, 2008 | 04:12 PM
wbwhiteboy's Avatar
i think you MIGHT have change the flywheel if your putting the stall from a f-body on. I think? im not posative. i swapped mine out for an LS1, but i did mine cause mine was slightly bent.
