Transmission fluid 1/2 quart low!
Old Jun 19, 2008 | 06:21 PM
Jeff 97 Formula's Avatar
Unhappy Transmission fluid 1/2 quart low!
Just recently, I noticed my transmission sometimes shifting softer from 1st to 2nd (even at half throttle, with the Hypertech tune firming up the shifts). The few times I had it floored, it still shifted nice and firm when it should (chirping in 2nd).
I decide to check my tranny fluid and added one-half quart, took it out again and it's shifting like it should once again. The fluid was flushed 2000 miles ago and still looked pinkish-red.
Should I be worried about possible damage to the transmission? Thanks!
Old Jun 19, 2008 | 06:26 PM
performabuilt's Avatar
LS1Tech Sponsor
Probably not but it does show that with the 60e there is no such thing as a little low.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 19, 2008 | 09:36 PM
Are my clutch packs shot? It was not slipping when it was not shifting, just felt a bit softer (as if I did not have a tune on my transmission). That said, is it possible the 'firmer shifts' saved the transmission somewhat?
Old Jun 19, 2008 | 09:39 PM
LS1Tech Sponsor
its was not good for them but i doubt they are shot th lower presure was caused by air mixing in But i doubt any substantial damage was done,
__________________
Call 888-744-6542
Old Jun 23, 2008 | 07:41 PM
I know it wasn't good for them. I was just curious to know if I would've been worse off if I didn't have the firmer shifts programmed in.
Just tested it again, still seems normal.
EDIT -- No SES lights resulted from this scenario.
Old Jun 23, 2008 | 08:12 PM
LS1Tech Sponsor
Its hard to say there , It may have helped some since even high pressure compressed air and fluid is better than low pressure of the same lol
__________________
Call 888-744-6542
