4L60E hitting the rev limiter???
New to the link so excuse any mistakes! I am hitting the rev limiter between 1-2 gear. I have the Power Programmer III and have the rev limiter set about 400 RPM's above the shift point. Have no problems unless I take off really hard. It will hit the rev limiter 2 or 3 times before shifting. I have already serviced the transmission and have the correct amount of fluid in it.
If I end up needing a rebuild what are some of the options to beef up the trans a little. I only have a few upgrades - Power Programmer 3, Underdrive pulley, K&N airfilter, Granatelli MAF, 3:73 gears, and flowmaster exhaust. What do you guys suggest. Thanks in advance
topless you runnin an ls1 if so how do you like the limiter set so high i have mine at 6600 rpm and am mostly stock so far good fill me in if you are in simlar situatiuon
reply to jpr5690@aol.com
thanks,john
thanks,john
