transmission
Old Jul 4, 2008 | 12:53 PM
XREDxTAx's Avatar
Default transmission
ok i have just ripped my second 4l60e out of my ls1 trans am and im looking to do a t56 swap i am trying to figure out EVERYTHING i need to do the swap.. please someone help thanks
Old Jul 4, 2008 | 01:38 PM
itchygomey98's Avatar
master & slave cylinders
master cylinder u-bolt and nuts
pedal assembly with clips for clutch rod and brake rod
console tray with shift boot, and lower shift boot
pilot bearing, bellhousing, crossmember, torque arm mount and bolts
pressure plate, flywheel, clutch
Transmission
Shifter
And a pcm flash for your car or a 6spd pcm
Old Jul 4, 2008 | 01:51 PM
04gtoBMXracer's Avatar
you might get a better response in the transmission section...
