Still hitting rev limiter between 2-3!!!
PS...went from 12.445 @ 114 to 12.285 @111 with the addition of the gears, the tranny and from the stock converter to a TCS 3500. The air was TERRIBLE on the second set of runs (after mods) and great on the 1st set.
60's went from 2.1 to 1.7
Anyone??? Lastly, can I adjust my shift points with affecting my motor tuning?
Shift points are not easy to do on the dyno.At the track it would have been ideal to get an Autotap run to see if KR was present and where your shift points are at.
BTW,I think you would have gone 11s if your shift points were on the money.
I was also plagued with the 2-3 rev limiter bounce. You need your rev limiter set at least 200rpms > than your highest shift rpm.
You should invest in Edit and DIY. Hell you bought every thing else for it. I'm jealous... I'm still trying for a low 13!
... Ron
I tried the OD thing... no dice.
