Pumps going out on 4L60Es
If you install the trans yourself make sure the spaced in between the converter and flywheel (before you bolt up the converter) is about 1/16" to 1/8". If the "pull back" for the converter is not with in this range then it could damage pump.
Kevin Steele
TCI
Product Engineer
